those who use mechanical speedo gears on electrical cluster.
Old Jul 15, 2009 | 01:47 PM
SebringZ's Avatar
Is it even possible? I have an 92' gauge cluster(RS) and threw in a 87 LB9 engine along with a T-5 from an 85' Z28. Transmission is in excellent shape so I'm keeping it. I'd rather stick with the 92' electrical gauge cluster, Is there a conversion that's popular that'll help me work both units?
Old Jul 15, 2009 | 04:39 PM
big gear head's Avatar
Re: those who use mechanical speedo gears on electrical cluster.
I use a 4 pulse speed sensor that I got from JTR. It screws onto the speedometer gear on the transmission and allows me to use the speedometer cable too.
Old Jul 16, 2009 | 02:01 PM
SebringZ's Avatar
I want to run an electrical plug if its possible to the VSS.
Old Jul 16, 2009 | 05:45 PM
If you have a VSS then you just need this sensor. I connected mine to the ECM so that the Camaro fuel injection would work in my truck. I still have the cable drive speedometer, so I needed the cable too. You might be able to use the Auto Meter speed sensor for yours. I have one in my '69 Camaro with the electric Auto Meter speedometer.
Jorlain
Aug 24, 2022 05:11 PM
Dialed_In
Aug 20, 2015 01:45 PM
mizz0313
Aug 12, 2015 06:45 AM
