Clinking sound from rear end when turning
Old Oct 29, 2001 | 03:21 PM
Adam62083's Avatar
Sometimes when I turn it clinks and the car kinda stutters and goes. Is the differential gear eating it or what?
I just had the pinion seal, bearing, and crush sleeve replaced, so I know those are good.
The car is a 1992 Formula 350 so it has a posi rear end, stock 10 bolt.
Old Oct 29, 2001 | 03:36 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
When the work was done on the rearend last time was the posi additive put in with the fluid?
91 Z28
Come see The Vicious...
Old Oct 29, 2001 | 03:49 PM
Adam62083's Avatar
I had told them to do it but I am really not that sure if they did. Is there a way to tell if they did, like the color of the fluid? Or can I just buy some from somewhere?
Old Oct 29, 2001 | 06:25 PM
ede's Avatar
ede
buy a bottle from gm and put in it
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Oct 29, 2001 | 06:27 PM
Adam62083's Avatar
Do I just dump it in where the inspection cap thing is? what if the fluid is full already?
Old Oct 29, 2001 | 07:49 PM
HARDWORK's Avatar
it sounds like dejavu to me!man,that brings back bad memories.the spider gears in mine had gotten chewed up inside the ring gear and the whole thing had to get replaced.i hope i am wrong,but i would get it checked out again.later
"Let's get to it,well let's do it!"
Old Oct 30, 2001 | 04:33 AM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
Yup, just put it in through the inspection hole. It ought to be full, but put the additive in anyway and let it displace the fluid already in there. Definitely try this before condemning the entire rearend.
91 Z28
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
novaderrik
Aug 10, 2015 12:44 PM
