bw limited slip question
Subscribe
Oct 28, 2001 | 01:18 AM
I have installed a borg warner limited slip rear end in my car. I still only seem to spin one tire most of the time. The other one will kick in but I dont know when or how often. I was told that this could simly be because they did not spin both wheels unless you put enough power to them. Is this true, or does something need fixed. Thanks for your help.
Ben
Reply 0
Oct 28, 2001 | 01:43 AM
the bw rears are posi.... both will spinn unless its a bad carrier..
305, TPI,compucam 2030 cam, air foil, 8.8 wires, accel super coil, dynomax headers, custom y-pipe, cut out, 80 series flowmaster, 2.73's and an open diff(3.42-3.73 on the way). and a stage 4 chip :0). hittin a sad 15.2 before the chip.
Reply 0
Oct 28, 2001 | 10:15 PM
If both wheels don't spin with a posi carrier, then the carrier is toasted.
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES, it is a 9 bolt & YES they are 3.73's, not 3.70. I currently have 4.10 gear sets and new series 3 carriers in stock for 9 bolts )
www.koolmeister.com
Reply 0
Oct 29, 2001 | 10:37 AM
Well, try a big burnout and if you're not getting 2 stripes then you (like 88427Camaro says) got a carrier problem..
You can try this first, but like it says, if the cones have eaten into the ends of the cases, it's toast... Get a new one from him, or search for a used one. https://www.thirdgen.org/newdesign/t...tservice.shtml
'89 Formula - Thunderchicken - 355 Vette L98/T-56/3.70 9-bolt/black/t-tops - the fun car!
'90 GTA - The GTA - 5.0 LB9/TH700/3.27 9-bolt/black/t-tops/tan leather - the cruiser.
Reply 0
Oct 29, 2001 | 11:10 AM
Well that is expensive crap. I hope it is good, but if not that will give me a reason to buy a series 3 carier and gears. I had thought about doing that anyway but thought I would wait a while just because of the price. Thanks for your help.
Reply 0
Oct 30, 2001 | 09:48 AM
I had a friend watch the tires as I held the brake and spun the tires. He said that they both spun but one stoped and the other kept going. The one that stoped started going again. I have a hard time even spinning my tires like this with my 126000 mile lg4 with 2.77 gears and 245s. So does this mean that it is good or bad or on its way out or what I really just dont know.
Reply 0
Subscribe
