What the hell is this??? (pic inside)
Old Oct 31, 2001 | 05:27 PM
DFIance's Avatar
Ok I know that the one on the left is obvious the shifter cabke that goes to the trans but what is that other cable? It runs up into the dash? I have no clue. I have a B&M shifter that I want to install but I know I wont be able to hook up the other cable, and I wont be able to put the nuetral saftey switch on, Will this matter?
Old Oct 31, 2001 | 05:38 PM
gmanuel's Avatar
That is for the lock in the ignition switch. No key no shifting into gear.
83Z28, 350,5speed,TTops,Heddman Shorties, mild cam, K&N air filter.
Old Oct 31, 2001 | 06:04 PM
DFIance's Avatar
ahhh I see I dont need that then. Well what should I do about the nuetral saftey switch? Can it be rigged up?
Old Oct 31, 2001 | 06:40 PM
quickL98's Avatar
Car: 87 trans am GTA
Engine: tesla permanent magnet
Transmission: 93 T-56
Axle/Gears: moser 12bolt w/ 3.73
your carpet looks pretty clean
my rigged up my p/n switch with 2 relays i can ask him what he did though.
87GTA ,10.5:1,4-bolt 355,afr 190's, super ram ,stock poerted base,58mmTB,24 lb FMS inj. ed wright chip, .510/230 (nr) 1&5/8 hooker shorty's, flow master single 3", 2800 ameri-torque non lk-up, 3.73. best to date with stk 48mm tb and lack of traction in 1st gear netted me a 12.9 @110mph /91 TA daily driver LB9 A4 2.73
Old Oct 31, 2001 | 06:45 PM
DFIance's Avatar
Well im supposing you saw my updated carpet install in the interior section? If not here https://www.thirdgen.org/messgboard/...ML/003951.html
Hotrodboba400
Dec 10, 2019 07:07 PM
Lanz06
Mar 13, 2019 06:07 PM
Fronzizzle
Sep 8, 2015 12:10 PM
dimented24x7
Sep 6, 2015 03:51 PM
Ian Irvine
Sep 4, 2015 08:08 AM
