I was changing my rear end lube and I found a u shaped thing stuck to the magnet on the cover. I'm wondering what this is for and what do I do with it? It looks like the c clips are in place so I don't know what this is from.Unless a previous owner left it in there on accident.
umm..that keeps your axle from flying out the axle tube if it's your c-clip...which is the only U shaped item inside the rear....put that on quickly before you even consider driving again.
i think both clips are in and i haven't had any problems with it in the past.
heres a link to what it looks like but if theres only two clips then i think they are in.
http://www.off-road.com/trucks4x4/da...789/C-Clip.jpg
if that was what was stuck to the magnet, that's not good..but if both are installed..maybe someone left an extra floating around inside?
