High RPM's low speed, tranny loads up
Old Nov 1, 2001 | 03:24 AM
Jstcrzyengh's Avatar
Car: 1988 Camaro Convertible
Engine: 355
Hi Guys,
Here the situation. Whenever I step on the gas the car "loads up" than once I release the gas a bit it might break free but keeps the RPM's in the 5k range!!! So I really have no "flooring it" availability. As well when I first start the car my idle is 2500 RPM's! and normal driving range I am around 1000 Rpm's higher than i should be, specially on freeway driving. Doing 90 in 4th (OD) puts me about 4000 RPM. I am dropping in an LT1 so any info is greatly Appreciated before the beast goes in.
Thanks,
James
1988 Camaro SC Convert!
4th gen conversion coming soon!
Old Nov 1, 2001 | 07:23 AM
82camaro's Avatar
Car: 82 camaro SC
Sounds like the tranny is slipping like crazy. If so, it needs rebuilt/replaced if you have driven it like that for any amount of time. With 3.73's and short tires I turn around 2500-2600 on the interstate. Is it even shifting into 4th? How accurate is your tach? The high idle is unrelated to the tranny.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Old Nov 1, 2001 | 10:31 AM
Engine: 355
The Car has always been like that. It does have good pick up and go once I am moving but only if I ease it up aggressively. I know that sounds like an oxymoron, but that’s the best way to describe it. Any suggestions on a rebuild so that it can handle the LT1 or an LS1 which might be the more likely choice? Im never taking my car to the track I just like to get to vegas fast and look good doing it. So street is the best way all around would it help if I dropped in a 4th gen rear with the 3.42 posi?
James
[/B][/QUOTE]
Old Nov 1, 2001 | 11:15 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
<font face="Verdana, Arial" size="2">Originally posted by Jstcrzyengh:
James
</font>
[/B][/QUOTE]
Well, if it is high speed highway cruising on deserted desert highways, then go for 2.73 gears. With an LS1 hitting 130mph and sitting there would be a laugh.
The speeding ticket wouldn't, though
Old Nov 1, 2001 | 11:21 AM
Engine: 355
<font face="Verdana, Arial" size="2">Originally posted by Sitting Bull:
</font>
lol Thanks sitting bull lol
The only speeding ticket I have ever received was on my old 94 explorer sport if you can imagine that. Knock on wood. What did you mean when you said hit 130 and not go anywhere, do you mean the RPM's would be really low? I already chirp right now when I take off so more chirping would be bad lol I like peeling out but when you barely step on the gas and it chirps thats bad... I either load up when floored or chirp when barely stepped on... My tranny must really hate me, though it has gone back and forth from AZ/NM border three times now in the past three months and Im in So. Cal lol Should I change the torque converter for such a engine change?
Old Nov 1, 2001 | 11:49 AM
Engine: 305-4v
I meant that sustained cruising at 130 mph with 2.73s and an LS1 would be a piece of cake. Your rpms would be quite within the comfort range of an LS1, especially in overdrive.
Old Nov 1, 2001 | 11:50 AM
86IROCTHD's Avatar
Car: 88 Trans Am
Engine: lt1 intaked 355 makin 277 on 25 psi of fuel pressure and stock timing :)
Transmission: A4 stock... that moved a mobile dyno a foot shifting into 2nd :)
sounds like your tach is bad... mine used to read double.... i thought my 305 was ballanced and blueprinted and stuff. cause it said i was hittin 7000 rpm... but i was sadly mistaken
Old Nov 1, 2001 | 11:59 AM
Engine: 355
<font face="Verdana, Arial" size="2">Originally posted by 86IROCTHD:
sounds like your tach is bad... mine used to read double.... i thought my 305 was ballanced and blueprinted and stuff. cause it said i was hittin 7000 rpm... but i was sadly mistaken</font>
I thought maybe he tach, but the entire car loads up and doesn't go anywhere when I floor it and it really does go WAY into the RPM's you can here it start wailing like a banshee. So I guess it's a new tranny for me?
theshackle
Sep 17, 2020 08:26 AM
Fronzizzle
Aug 19, 2015 01:36 PM
jbd1969
Aug 17, 2015 07:06 PM
perZ
Aug 15, 2015 01:17 PM
novaderrik
Aug 10, 2015 12:44 PM
