700r4 bad or what the heck is the prob
i got a huge problem my 700r4 is acting up checked fluid and its full. Recently changed filter and fluid. The wierd thing is that it can go into gear and shift when its under 170* after it gets hotter then that it wont even go into gear.. Anyone had this problem b4 what do you think is wrong thanks for the help.
Car: 1988 Camaro SC
Engine: 355 Chevy
Transmission: 700
Sounds like you need a rebuild. Hard seals seem to be your problem.
1988 Camaro Sport Coupe: Orignally: 305 TBI 700r4
Now: 1974 355CI, 2bolt, Badger Flat Head Pistons w/ valve relief, Melling high performance street cam, GM Cast Vortec Heads, Edelbrock RPM Air Gap Intake, Edelbrock 600cfm w/ electric choke, GM HEI w/ vacuum advance, Weiand Low Profile Air Cleaner, Mallory 5 port Fuel Pressure Regulator, Mr. Gasket Throttle Cable Bracket, Corvette Shift Servo, 16" IROC Wheels, Every thing else is STOCK
Soon: 3.73 or 3.42, Gears, Hoosier Q/T
Hotrodboba400
Dec 10, 2019 07:07 PM
tglennon11
Interior Parts Wanted
Sep 11, 2015 10:25 PM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
