Auto to manual conversion
Old Jul 22, 2009 | 06:47 PM
89_RS's Avatar
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
I'm currently contemplating switching from a 700R4 to a Richmond 6-Speed, but I need help in figuring out what all is needed.
Heres what I know I need and have found so far:
Trans
Torque Arm
Driveshaft
Bellhousing
Clutch & Pressure plate
Flywheel
The only things I can't find are the "pedal box" and related items. Any and all help is appreciated
Old Jul 22, 2009 | 09:20 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Auto to manual conversion
the pedal assembly is uaually on ebay, sometimes here in the classifieds.
are you using the hydraulic clutch? you will need the master/slave setup as well.
what richmond 6 speed are yo uplanning to use? the retrofit t5 replacement or what? a lt1 style t56 is not a bad idea.
Old Jul 23, 2009 | 11:02 AM
89_RS's Avatar
Car: 2003 F-150
Transmission: 4R70W
Originally Posted by //<86TA>\\
the pedal assembly is usually on ebay, sometimes here in the classifieds.
what richmond 6 speed are you planning to use? the retrofit t5 replacement or what? a lt1 style t56 is not a bad idea.
Thanks for the info.
A hydraulic clutch was all I could think of, so thats kinda what I was thinking of going with. What all is required for a hydraulic clutch? This is along the lines of the clutch kit I was thinking of:
http://www.summitracing.com/parts/ACL-GM7-HDSS/
The Richmond I'm looking at is the T5 retrofit. I looked at the LT1 T56, but I really like how much closer the gearing on the Richmond is. The Richmond also has the same 6th gear ratio as the T56: .62 to 1.
One quick question about the driveshaft. Since the Richmond is a T5 retrofit, will the T5 driveshaft work?
Old Jul 23, 2009 | 01:42 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
There is a sticky post at the top of this forum, as well as two tech articles (in the tech articles section of the main website) that should help answer your questions. They apply to the T56 swap but it should be similar enough.
Good luck with the swap!
Old Jul 29, 2009 | 08:18 PM
89_RS's Avatar
Car: 2003 F-150
Transmission: 4R70W
Thanks for pointing out the tech articles, they really helped explain alot of stuff in the sticky.
I read the sticky and the tech articles and the only two questions I have left are these:
Do I need a hydraulic throwout bearing if I use a hydraulic clutch?
Can the T5 driveshaft be reused on the Richmond?
EDIT: Nevermind about the driveshaft. In another thread I read that all you have to do is change the yoke on the transmission end of the driveshaft and you're good to go.
Other than those questions, I now know all the parts I need and have pretty much got a good idea of how to do the swap
LittleFranks
Oct 7, 2015 11:26 PM
88rscamar0
Sep 23, 2015 09:08 PM
Randomtask2
Sep 7, 2015 05:06 PM
!CamaroDave
Members Camaros
Sep 5, 2015 10:39 AM
