Which rear end to use???
Old Jul 24, 2009 | 03:13 AM
consequence's Avatar
I currently have access to 3 3rd gen bodies and I was wondering which rear end to use, sorted conflicted after reading...
1. 85 IROC-Z (junk car) with a 9 bolt BW, dont know the ratio but it aint a posi.
2. 83 Camaro (The car which I intend to fix) has a 10 bolt, dont know the ratio but it also is not posi.
3. 85 Trans Am (more junk) unfortunately the only thing I know about this is it has rear discs. It had a 350 (swapped) in it and it might have been the high model as it had the T-shifter but not 100% if that was standard with all models.
I am leaning towards the 10 bolt on the 83 as it is A: on the car I am fixing, and I was gonna take the disc brake parts off the Trans Am and get ed's plates for the conversion from drum.
but...I have seen the 9 bolt is a good diff just hard to find parts.
Hoping someone can help with the decision. I eventually need to ditch the 2 parts cars but i wanna make sure I get the better parts off the other cars before they go...
Also any other parts I should take off the trans am? I have heard the suspension (maybe ws6 dunno never looked) might be good but again first 3rd gen rebuild here so I am learning on the fly.
Old Jul 24, 2009 | 07:04 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Which rear end to use???
Welcome to TGO. I'd certainly consider gear ratio before making a decision. Perhaps the following link will help in that, at least where 10-bolts are concerned:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Jul 24, 2009 | 10:15 AM
86Z's Avatar
86Z
Car: 1986 Camaro SC
Engine: 305 TPI Procharged D1SC
Transmission: Tremec TKO-600
Axle/Gears: Moser 12 Bolt 3.73 posi
None.
Moser 12 bolt... nuff said.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
