87' trans into a 91Z questions........
Old Nov 5, 2001 | 01:39 AM
Chris Etemadi's Avatar
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
I just pulled a 700R-4 out of a 87 camaro I have 2 questions.
1. How would I convert the cable driven speedo to the VSS style
2. It was in a camaro with a carburated 305 with 71K miles. My car and mods are listed below. How long would you guys expect it to hold on??
91 Z28 5.7l Camaro
T-56,McLeod Street Clutch, Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
Old Nov 5, 2001 | 04:59 AM
transfixleo's Avatar
You will have to take the tail housing off and replace the plasic speedo gear with the metal one from the later tranny. Use the pickup sensor too.
Old Nov 7, 2001 | 06:54 PM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
transfixleo knows his $h!t. He helped me with the exact same problem. I'm putting an 87 into a 92 car. Does the tail housing have a gasket that needs to be bought, or will black RTV do the trick?
Old Nov 8, 2001 | 12:07 AM
Car: 1991 Z28
so which speedo gear do I change?? the drive or the driven one??? I thought all the 700R4 speedo gears were plastic
Old Nov 8, 2001 | 02:15 PM
Your '92 probably has the electronic sensor. If so just replace the speed with the sensor and put the reluctor on in place of the plastic gear on the shaft. There is an O-ring readily available at any tranny shop for maybe a buck. If you do have a speedo gear still check the count on the tranny gear and if it is different then change over to the original and reause the driven gear. If it is the same then you are all set on that.
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
Hello, Michael
Aug 20, 2015 03:19 PM
mizz0313
Aug 12, 2015 06:45 AM
Leggman1
Aug 6, 2015 04:15 AM
