700r4 compatability
Old Jul 28, 2009 | 10:07 PM
lilnebel's Avatar
Car: 1991 Camaro Z28
Engine: 5.0 V8 TPI
700r4 compatability
I am looking at buying a used 700r4 from a 1984 camaro to put into my 91 just wondering if it is a simple swap. and if there is any reason why not to buy it other than its used.
Old Jul 28, 2009 | 10:12 PM
85camarojunkie's Avatar
Car: Camaro coupe
Re: 700r4 compatability
Depends. Is your 91 an auto or manual. If its an auto simple swap but why. is your current one missing/shot. Your 91 came with a 700 so other than that if yours is good no since in buying it. I think the 84 is a metric trans to, so if nothing is wrong with yours let it be or do a 6speed swap. haha
Old Jul 28, 2009 | 11:19 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
It would be a straight swap I assume ... but - in late 1987 they beefed up the internals on the 700R4, so anything older will be slightly weaker ... UNLESS this older unit has been rebuilt with the newer stronger internals.
Old Jul 29, 2009 | 01:50 AM
ikillu's Avatar
Car: 91 Z28
Engine: 383 stroker HSR
Axle/Gears: 3:73 posi
I'm actually curious about this too as i was told pre 87 700r4's won't work in a 91.
Old Jul 29, 2009 | 08:29 AM
Car: Camaro coupe
See if the car has the LG4 or L69 motor. IF it does snag the rear end to, its a 3.42. and just double checked myself, an 84 is the first year of the 700R so my suggestion again, if there is nothign wrong with the one in your 91 stick with it.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
