83 5 speed clutch adjustment
Old Jul 30, 2009 | 06:55 PM
3rdGenSuperman's Avatar
Car: 1983 Camaro Z28
Engine: 305 cu.in
Transmission: stock
Axle/Gears: stock
Hey guys, I recently bought a car, and it's not engaging the gears very well.
I will try and adjust the clutch before changing it, I have a shop manual but I think that the instructions are generic and not for the car specifically.
It's a linkage system, no hydralic. What is the best way to adjust this clutch?
Old Jul 31, 2009 | 01:57 PM
jmd's Avatar
jmd
Car: `86 SS / `87 SS
Re: 83 5 speed clutch adjustment
On some "traditional" clutches, the linkage should be adjusted (the lower pushrod in your case) so that the throwout bearing has approximately .050" air gap between itself and the pressure plate fingers. Check the spec for your car.
deracer
Apr 11, 2016 12:04 AM
Eric2ndGen
Nov 5, 2015 01:51 PM
theshackle
Aug 31, 2015 10:47 AM
hayesaw0210
Aug 23, 2015 11:15 PM
redmaroz
Aug 16, 2015 11:40 PM
