Wheel spacers, NHRA legal? Safe?
Subscribe
Nov 13, 2001 | 01:49 PM
I was once told that wheel spacers were not legal at the track (at least on the rear). Is there a real danger of these things shearing off? I want to go with 4th gen wheels eventually, I already got a BW/disc rear and don't want to drop in a 4th gen unless I have to. Thanks...
-='89 Iroc-Z - 350 TPI =-
Reply 0
Nov 13, 2001 | 02:40 PM
Not sure about NHRA legality but you will need longer wheel studs to compensate for the spacers. We run spacers with long studs on all 4 wheels of our SCCA road race Triumph Spitfire without a problem.
Reply 0
Nov 13, 2001 | 02:47 PM
i have mixed thoughts about them. I had a wheel fall off my car at englishtown this past april because the spacer lugs loosened and detached from the hub. The reason it happened was because they were installed improperly without washers by a shop. I had them reinstalled correctly, and I have had no problems at all with them since april. Of course the car maybe has 500 miles on it since april, so it's not like it's a daily driver by any mean.
But they still kind of make me uneasy, and the shop that installed them actually said they could fail me on inspection for them.
Reply 0
Nov 13, 2001 | 05:25 PM
That was you???
Did it do any damage?
Reply 0
Nov 13, 2001 | 06:07 PM
i belive you can only use like a 1/8" on the front only, they are dangerous on ANY car as is make the grip on the lugs looser and doesnt hold the wheel on as good, nothing would be worse then hauling some a$$ and having a wheel come off
Reply 0
Nov 13, 2001 | 06:46 PM
If you use long studs, there shouldn't be a problem, a TON of SCCA race cars use them. Granted, they usually don't see hard launches.
84 Z28 L69. 5 speed with 3.73 posi (broken)Ported heads, intake, 10:1 comp. 230/230 .480 lift cam @.050"
Reply 0
Nov 13, 2001 | 06:56 PM
formul8, yep, that was me.... I actually came out ok on damage. All the wheel studs on that hub, the gfx piece under the door and the fender were all that bit it. Only thing that shows now is some paint that doesn't quite match.
here's a few pics of the whole deal:
The day of:
http://www.poorformance.net/iroc/gmhtp.jpg
New fender hung and repainted first time:
http://www.poorformance.net/irocpics/brokengfx.jpg
http://www.poorformance.net/irocpics/fender2.jpg
Recent Pic:
http://www.poorformance.net/irocpics/10-14-curriroc.jpg
I did the fender a second time hoping to get damn close on the paint, but it's not quite right. Maaco painted the whole car last, and they apparently just invented a color of their choosing. Forget trying to get touchup paint. The car's gonna get repainted right after the motor and trans are all done.
TempesT68, the type of spacer we're talking about actually has holes in it to bolt onto the stock hub, and then studs to bolt the wheel onto. They come in thicknesses of 1" and up. My car has 2" spacers all around to fit 4th gen SS rims.
Reply 0
Nov 13, 2001 | 08:24 PM
[QUOTE]Originally posted by BitchinCamaro:
[B]I was once told that wheel spacers were not legal at the track (at least on the rear). Is there a real danger of these things shearing off? I want to go with 4th gen wheels eventually, I already got a BW/disc rear and don't want to drop in a 4th gen unless I have to. Thanks...
technically, you will be using adapters. these bolt to the studs and have another set of studs for the wheel. they are about 1.5 inches thick. but. yes NHRA illegal. now if you are just going to the track for a test and tune night. don't worry. if you are using that car for drag racing in the NHRA sanction, then you can't have.
Reply 0
Nov 14, 2001 | 12:10 AM
lol, HELL I EVEN HEARD ABOUT THAT....
thats wat i fear, and was making me study all this... im goin 4th gen rear either way,
but i just posted to say sorry bud...
91 FireBird 305 V-8
Edelbrock Catback, Custom Alarm. Fourth Gen Console. i have six cupholders. all for starbucks!
Go|)Created The Earth, And Then Turned Up The Bass.
Here's My Audio Install!
"Honda's FOR ME TO POOP ON!" -Triumph...
Reply 0
Subscribe
