700R4 to a TH350 - Speedo disconnected
Old Nov 14, 2001 | 09:53 AM
Loki1199's Avatar
Hi guys,
I searcehd the board and it looks like this is the first time this has been asked, so...
I had a TH350 put in my T/A when my 700R4 blew. The guy that put it in never connected my speedo because he said it wouldn't work with this tranny. Is this because I had an electric relay, and the TH350 has a manual gear or what? I need to get it to work to pass inspection since they installed the Dyno Test in Mass. inspection bays. If someone out there knows how I could get it to work, the help would be appreciated.
TIA.
Old Nov 14, 2001 | 10:57 AM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
Yep. That's the same problem I'm having with my TH-350. I've broke two speedo gears becouse everytime you go past drive the shifter cable smacks it. I don't know what to do, but I would like to find out.
-Matt
1984 Camaro Z28 - Black w/ Grey int.
-GM Goodwrench 350 with Edelbrock 600 Carb, Edelbrock Preformer RPM intake, AC Delco plugs, 8mm AC Delco wires, 14" Accel filter, Homemade Cold Air Indctn., Edelbrock Chrome valve covers, breather, and Air cleaner.
- Profesionally Built Turbo-350 with 2500 RPM Stall converter, Hurst shifter, & one wicked shift kit.
- Eagle Alloys 15" Alum. Rims surrounded by P235/60R15 BF Goodrich Radial T/A's
-Comming Soon:
3.73's, MAC Cat-Back, hollowed cat., B&M Megashifter, & Paint: Navy Blue Metallic w/ Silver strips
Pics at: http://members.fbody.com/flashz28/
Old Nov 14, 2001 | 04:26 PM
Jay 727's Avatar
Get a tail housing off a buick, olds, or pontiac th350 or th250. It uses the same speedometer gears and 2" sleeve as a 700R4 there for all speedo parts electric or mechanical will interchange.
The chevy th350 uses the 3/4" speedo gear sleeve.
Old Nov 14, 2001 | 10:31 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
<font face="Verdana, Arial" size="2">Originally posted by Flash84Z28:
I've broke two speedo gears becouse everytime you go past drive the shifter cable smacks it.</font>
How does that happen? The shifter cable shouldn't be anywhere near the speedometer gears.
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
6998poncho
Sep 25, 2015 02:56 PM
