still no 2nd gear
Old Nov 16, 2001 | 05:55 AM
PimpCamaroRS's Avatar
still no 2nd gear
i took out the billet servothat i installed inmy 700r4 and replaced it with the origanal servo. i still have lost second gear. my car just shifts from first to third and if i put it in the 2 -drive its almost like nuetral. the ppl at transmissioncenter.net said the 2-4 band coud be out of adjust ment.could that be true?and if so how do i re-adjust it? thanx
Old Nov 16, 2001 | 08:10 AM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
if you install the servo properly, it should adjust the band. Are you putting all the servo pieces in properly?
Old Nov 16, 2001 | 08:54 AM
yes i put it in exactly like i tok it out. servo retaining spring,servo piston,servo housing,spring,washer,e-clip to hold washer and spring, then 4th piston and cover......all te o0rings were intact so i dunno what would be wrong ther than the 2-4 band.
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
91L98Z28
Southern California Area
Sep 19, 2015 09:35 AM
georgiaslim45
Sep 9, 2015 08:12 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
