posi worn
Old Aug 6, 2009 | 12:29 AM
nightowls_gm's Avatar
Car: 88 IROC Z
Engine: 5.7
Axle/Gears: 3.27 9 BOLT POSI
posi worn
i just got another camaro its an 88 iroc 5.7 and it burns out one legger sometimes both kick in but its usually one tire. do they have posi rebuild kits or something i can do to get the posi back?
Old Aug 6, 2009 | 07:35 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: posi worn
Are you certain that the car's equipped with a limited slip? Some food for thought in the following link:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Aug 6, 2009 | 09:10 AM
big gear head's Avatar
Re: posi worn
Depends on which rear end you have. If it's the 10 bolt with an Auburn then the Auburn is trash. You will have to replace it with a new one. If you have the 9 bolt then you can recondition the posi at least one time. There are instructions on this sight about how to do this.
FormulasOnly
Jul 23, 2018 08:47 AM
KO1
16
Oct 15, 2015 05:00 PM
