400 sbc starter with a t5 ?
Old Nov 3, 2001 | 10:22 PM
83z28400sbc's Avatar
ok i have a small block 400 and ever other part to put the t5 behind it and i came down to the starter. lucky me my block only has two holes drilled in it. so i am wondering what or if any starter will fit the 400 with a t5 besides the opion of drilling a hole and taping it any info would help thanks
83 z28 400sbc 85 v6 88 v6
Old Nov 4, 2001 | 12:32 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No other option exists.
The inner bolt hole location is such tht a bolt in it would have to go RIGHT THROUGH THE MIDDLE of the starter drive. It is therefore not possible to use that bolt hole to hold on a starter that will work on a 12¾" flywheel.
On the 400 I ran in my 83 HO car for about 10 years, I drilled and tapped the extra hole.
ICON Motorsports
Old Nov 4, 2001 | 12:37 PM
bhaas's Avatar
Drill the hole with a 5/16th and tap it with a 3/8th.
1986 SC Camaro
Mods: Threw 2.8 in garbage, put in rebuilt
350 .060 over, XE268H Comp cam, Edlebrock
Performer Intake and Edlebrock 600 CFM Carb,
Pete Jackson noisy GearDrive (which sounded
cool for about 5 minutes, now I'm sick of it)
Rebuilt TH350, 3.42 Rear Gears. LCA RLB's.
B&M Mega Shifter.
Now has T5 in it. YES!!!
CenterForce Dual Friction Clutch.
Old Nov 5, 2001 | 05:21 PM
Bandit406's Avatar
Where did you find the externally balanced flywheel? I can't find a lightweight flywheel anywhere.
Old Nov 5, 2001 | 06:16 PM
i used a early 12.75 350 flywheel with a pork chop weight. which i found at port city racing. for 15 bucks. they have a web site its portcityracing.com
but that is my plan i dont know how it works yet cause i still have to drill a hole for the starter. but when i do i will let u know
Old Nov 16, 2001 | 09:20 PM
well i finally got the swap done and so far so good. the v6 tranny does have low gears but not too bad considering i have 3.23 rear gears. but let me get some miles on it then i will reply again.
Hotrodboba400
Dec 10, 2019 07:07 PM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
sahlomonic
Sep 20, 2015 07:15 PM
deemoney
Theoretical and Street Racing
Sep 13, 2015 07:02 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
