Largest Swap Without Buying New Carrier
Old Nov 18, 2001 | 07:31 AM
Black N Yellow RS's Avatar
I got the stock 2.73 gears and wanted to put 3.55's or even 3.73's in my car......would i have to buya new carrier in order for them to be compatible? if so what is the largest i can go without a new carrier? if not let me know thank you
Old Nov 18, 2001 | 07:40 AM
Jay 727's Avatar
I have an auburn limited slip, it says it's good for 2.73 and up gears and I have 3.73's on it.
If you look in a catalog like summit or jegs you will find this information.
Old Nov 18, 2001 | 09:48 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
You can go as high as 4.10s w/ the 2.73 carrier, but the key is to find those gears specificly for two series carriers I have richmond 3.73s on my stock 2.73 posi.
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Old Nov 19, 2001 | 02:50 PM
82camaro's Avatar
Car: 82 camaro SC
3.08 and down 2 series
3.23 and up 3 series
Aftermarket gears can be had with the deeper gears on a 2 series carrier--Richmond for example. Keep in mind that with the deeper gears you will really wish you had a posi/locker.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
hectre13
Dec 11, 2023 08:14 AM
midge54
Sep 2, 2020 07:13 PM
hectre13
Aug 26, 2015 08:17 AM
theurge
Aug 21, 2015 12:46 PM
knight72
Aug 10, 2015 09:32 PM
