question about speedo gears
Old Aug 9, 2009 | 09:53 PM
MSRed91Camaro's Avatar
Car: I have a 91 Camaro RS
Engine: 383 stroker
Transmission: Stock automatic 700r4
Axle/Gears: I have 3.73 Gears with a Eaton posi
I recently bought all the stuff I need to install 3.73 gears as well as to put posi into my rear end, I know with this upgrade to my stock 91 rs it will throw off the speedo and i know that this can be fixed by replacing to speedo gears in the tail end of my transmission what i dont know is what gears are needed to make my speedo accurate again , I belive that i was told that i will need the 15 tooth driving gear, but I dont know if this is correct or what type of other gears i need. I know that the tire size factors into the what speedo gears are needed and I have 225/55R17 tires and wheels what gear would be used for them. I have read some stuff posted about a forumla that I can use to caculate it but it is confussing to me any info would help me out alot
Old Aug 10, 2009 | 06:58 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
re: question about speedo gears
Phone the following company. They'll fix you up.
http://www.transmissioncenter.net/sp...n_______va.htm
JamesC
Old Aug 10, 2009 | 02:20 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
You could/ve just PMed me, but to be safe, use a 41 tooth driven gear, the part number for your local GM stealership can be found in my other sticky.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
You need a 42 tooth driven gear.
Old Aug 10, 2009 | 02:37 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
can also be done with computer chip re-burn.....I know your probably not at that point yet, but the 91' - are computer controlled and can be done both ways....just some info...
Old Aug 12, 2009 | 09:12 PM
Engine: 383 stroker
thanks for the info
Old Aug 17, 2009 | 08:12 AM
84z5350's Avatar
Car: 1986 z28
Axle/Gears: ?
Re: question about speedo gears
i own a 92 rs and just changed my rear to a 3.23 from a 2.73 any body know of the top of their head what tooth i'll need and is it the one that pulls out where the speed sensor is ?
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Irocohio
Aug 12, 2015 08:03 AM
beachrodder
Aug 7, 2015 04:27 PM
