Speedo gears because of gears
Car: 1988 Camaro SC
Engine: 355 Chevy
Transmission: 700
Can someone please help figure out what speedo gears I need? I went from a 2.72 or 2.73 to 3.73. My drive gear is a Red 17 and the driven is a Red 37. Please help.
1988 Camaro Sport Coupe: Orignally: 305 TBI 700r4
Now: 1974 355CI, 2bolt, Badger Flat Head Pistons w/ valve relief, Melling high performance street cam, GM Cast Vortec Heads, Edelbrock RPM Air Gap Intake, Edelbrock 600cfm w/ electric choke, GM HEI w/ vacuum advance, Weiand Low Profile Air Cleaner, Mallory 5 port Fuel Pressure Regulator, 3.73 Posi, Mr. Gasket Throttle Cable Bracket, Corvette Shift Servo, 16" IROC Wheels, Every thing else is STOCK
Best Times:60ft 2.26 1/8th 9.68 @ 73.63 Hoosier Q/T
https://www.thirdgen.org/rides/index.tgo?action=view&rideid=7480
Car: 1991 Z28
Engine: 5.3 Gen III SBC
Transmission: 4L80E NTC 258mm Stall
Axle/Gears: Trick Chassis 9" 3.50 S-Strac
for 245/50-16's in the back You will need a 15 tooth (gray Drive Gear) and a 45 tooth (Light blue driven gear)
91 Z28 5.7l Camaro
T-56,McLeod Street Clutch, Cross Drilled Brakes, KYB's,AFPR, 3.73 Gears, Borla Adjustable Cat Back, Hypertech Chip, Hooker Headers.
more to come....
My 91 Z28
91 Z28 5.7l Camaro
more to come....
My 91 Z28
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
A 15T Gray (8642620) Drive and a 44T Dk. Gray (9780470) Driven should work. Need your tire size to tell exactly.
[This message has been edited by Apeiron (edited November 19, 2001).]
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
