9 bolt ratio question
Old Nov 20, 2001 | 10:19 PM
Momar's Avatar
Does anyone know how many teeth the gears for the 9 bolt 2.77 have. Is the 9 bolt 3.08 the same as the 10 bolt. What I was wondering is: I have 2.77s in the rear that is in my car. I have another in my garage with 3.08s. Would it be possible to use the ring gear from one and the pinion gear from the other to get lower ratio gears than are normally offered for a series 2 carrier on a 9 bolt.
Ben
Old Nov 20, 2001 | 11:28 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
You can NEVER mix ring & pinions.
Chronologically challenged. But still kicking!
'92 CAMARO RS
305 TBI 5/spd (now TPI)
B4C Alt.
Cam change:TRW 198/210 ,450/.460 114 LSA
Stock TBI manifolds
'85 IROC 3" Cat. back Exhaust
14.94-92.00 mph
SDPC base and "350" Vortec coming soon!
'69 camaro-BB/Lenco,1050 dominators, /Pump Gas/no drugs 8.97-150+/3200lbs.
SoCal Thirdgen F-Bodies
Old Nov 20, 2001 | 11:48 PM
@ZZKKER's Avatar
Car: 86 iroc, 87 iroc, 89 iroc, 89 formula, 84 supra, 85 trans am
Engine: t\a motor 355 lt1 intake, t56,the works, 89 roc 427 sbc tt project
Transmission: to many to list
Axle/Gears: 9bolt 4:10 in the T/A
why not?
Old Nov 21, 2001 | 12:23 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Because they're a matched set. They only work with the same ratio, not other ratios. And once the gears have worn together, you shouldnt change one or the other, only both at the same time. Its kinda like you do with a flat tappet cam and lifters.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
317 RWHP, 418 RWTQ
13.23 @ 107.62 MPH (2.10 60')
Southern California
Member: SoCal 3rd Gen F-Bodies
Member: SoCal F-Bodies
-=ICON Motorsports=-
84z96L31vortec
Aug 20, 2017 12:16 AM
hectre13
Aug 26, 2015 08:17 AM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
