tranny mount busted?
Old Nov 22, 2001 | 12:29 PM
firbird's Avatar
I think my tranny mount is busted would this be a symptom of a broken tranny mount? When I give it adequate throttle to move and when it hits about 1500 rpm it makes a weird grinding feeling, it really doesn’t make a lot of noise but its more felt than heard, and it seems to come out of the area of the shifter. Today’s not my day was going to order a cat back then realize that my tranny is busted prolly and my injector just died and almost over flowed
Old Nov 22, 2001 | 01:19 PM
ede's Avatar
ede
broke trans mount sounds like a thud in the area of the trans tunnel, little bit aft of the shifter when you apply your right foot to the gas pedal. grinding sounds aren't from a brokem trans mount.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Nov 22, 2001 | 03:08 PM
firbird's Avatar
Well that’s great , what could it be could my transmission be broken itself? Because past 1500 rpm it’s just fine and if one of the gears was shot it or going wouldn’t it be worse the higher the rpm? I am just glade i am happy with a full stomach, happy thanks giving every one
Old Nov 22, 2001 | 05:52 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Do you have a driveshaft loop? I've seen drive shafts ground out on the loop w/ lots of flexing due to bad mounts.
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
GouldyGTR
Sep 7, 2015 09:05 PM
Stryker412
Sep 7, 2015 09:11 AM
apie2546
Sep 5, 2015 07:40 PM
IROCZ1989
Sep 4, 2015 11:54 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
