Speedo Cable
Old Aug 14, 2009 | 03:31 PM
mattmerritt89's Avatar
Car: 1987 Camaro
Axle/Gears: 4.56
Speedo Cable
What all do you have to do to replace the speedo cable in a 88 camaro. It did have cruise control didn't work so I'm wanting to get rid of it. Any info would be great. Also where can I get one.
Old Aug 15, 2009 | 06:55 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Speedo Cable
Remove the cable from the rear of the cluster and at the trans, remove a few retaining bolts and remove through the firewall. If you have a two-piece cable, I'd replace it with a one-piece. I purchased new from GM, but I'm sure you can find something at an auto parts store.
BTW, why do you want to replace it? It may simply require cleaning and lubing.
JamesC
Old Aug 15, 2009 | 09:44 AM
Car: 1987 Camaro
Axle/Gears: 4.56
Re: Speedo Cable
No it ran into the cruise control and thats what messed up.
Old Aug 15, 2009 | 05:05 PM
JamesC's Avatar
Re: Speedo Cable
I would have thought that the old style transducer would have been long gone by 88. At any rate, you can replace the two-piece with a one-piece.
JamesC
Old Aug 15, 2009 | 07:34 PM
Car: 1987 Camaro
Axle/Gears: 4.56
Re: Speedo Cable
Thanks alot for the help puting it on tomorrow
Old Aug 16, 2009 | 10:17 AM
DeanJ's Avatar
Car: 1988 Camaro, 1986 S10, 2000 Harley
Engine: LS6
Axle/Gears: 3.75 9" ford trac loc
Re: Speedo Cable
The speedo cable should not connect to the cruise on an 88 model. Is the cruise possibly a retrofit ? Dean.
Old Aug 16, 2009 | 11:13 AM
Car: 1987 Camaro
Axle/Gears: 4.56
Re: Speedo Cable
Idk it looked stock to me it was all racume operated and it was a mess so to hell with it you know. To much trouble to get it to work if I ever restore it I'll fix it.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
