Space Between TC and Flywheel
Old Nov 23, 2001 | 01:41 AM
ChevypickupTPI's Avatar
What do I do with the space between the flywheel and tc? On my truck i put washers in there, b/c thats what my tranny guy said to do? Works ok, just want to know what you all would do?
Old Nov 23, 2001 | 01:44 AM
ScreaminDeamin85Z's Avatar
the torque con. should slide up flush with the flexplate. but if washers work fine i'd leave it.
Brandon
"ScreaminDeamin 360"
1989 IROC 350 60 over, TRW forged 9.83:1 pistons,Hooker Comp headers, crane cam 216/228 .484/.512, crane 1.6 RR's, ported plenum, home made ram air, 24lb SVO injectors, crane AFPR, all going through 3 inch mandrel pipe and a flowmaster.
T-56 ,McLeod clutch, LT4 PP
Newest Pictures
http://screamindeamin.cz28.com/newimages
http://ScreaminDeamin.cz28.com
Old Nov 23, 2001 | 03:09 AM
transfixleo's Avatar
I always check (and space) the converter back on GM's. Often you will find too much clearance between the converter and flywheel. I push the converter in all of the way and then pull it out 1/8". Now I make up for the difference with washers (equal size of course). This allows the drive slot on the converter to fully engage the pump gear W/O pushing it into the backside of the pump. Many times a 350 will stop moving because the front face of the pump gears drive tang has worn off, PLUS it can tend to wear the pump due to uneven loading on the pump gear.
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
