700r4 prob
Old Nov 22, 2001 | 08:50 PM
PimpCamaroRS's Avatar
700r4 prob
i just installed transgo shift kit,boost valve, and billet servo in my 700r4. now i have no second gear and no forth gear. what i am thinkin is the big ole billet servo was to big to i put my old servo back in and it still does no have 2nd or 4th. so now i am pretty sure i busted my 2-4 band.am i on the right track guys? if i am how much is it to have some one profesionally fix it(about). thanx
Old Nov 22, 2001 | 09:01 PM
also if any one knows about rear ends....i plan on dropping a 383 in my 91rs(2.73) and tricking it out with all the best mods. i plan on getting 350+HP or maybe even 400+HP. Which is the best,cheapest!, way to make my rear take all those horses?
Old Nov 22, 2001 | 09:44 PM
transfixleo's Avatar
With the car solidly on four stands or a lift, with the tranny in Man2 push in on the Servo cover and see if it now 'shifts'. If so it is some sort of control problem or a WAY out of adjustment band. If it doesn't then you may have broken the band. That Servo is overkill. I don't use it on anything.
Old Nov 23, 2001 | 05:54 AM
Pro Built Automatics's Avatar
The lower the number of the rear end gear ratio the stronger the ring & pinion. The pinion has less teeth and the teeth are thicker, therefore stronger. How many 2.56's, 2.77's, 3.08's, etc. have you seen break? Check the pinion to ring gear clearence, and change it if necessary, and run a hi-quality rear end oil. Torco, Amsoil, etc., NOT Sta-Lube. If you have a posi, make sure you run the additive that is recommended for what you have.
Old Nov 23, 2001 | 10:15 AM
transfixleo, when i have the car on jack stands, do i start the car then drop it into Man2 and push on the servo to see if it shifts?if so how with i know if it shifts? will i here a clicking noise or what? thanx
Old Nov 23, 2001 | 04:08 PM
Yes, push on the cover while it is in Man2 but first make sure you have it solidly on stands/lift. Next, have someone inside to A) keep the tranny speed up to @20 (so it will be aproximate speed for 2nd gear) and when you push on the cover, if it does make it shift the other person will B) see it on the speedo and you will likely hear it too and see the driveshaft/wheels speed up accordingly.
Old Nov 25, 2001 | 11:51 AM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Is it possible that the anchor pin that's under the valve body came loose? Since he possibly had the servo and the VB out at the same time, I see how that could've happened!
Old Nov 25, 2001 | 01:46 PM
Yes, usually it is pretty solid in there but it could have happened.
Old Nov 25, 2001 | 05:04 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I asked him if he found any spare parts after the shift kit install (i.e. anchor pin) and he said no. I'm wondering if the big *** servo didn't eat his band for lunch. I have seen them punch the apply pin through the pin seat (remember Millicans?) and I have also seen them bust out the back of the anchor bung.
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Old Nov 25, 2001 | 05:35 PM
Very good point. That is why I try to steer people away from the overkill stuff.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
