difference between stock mount and poly mount??
Old Nov 27, 2001 | 04:59 PM
breathment's Avatar
what is the difference, if people are having so many problems with poly, and still using them, then what are the advantages?
- David
88' GTA 5.7L TPI MODS---> air foil, K&N, Shift Kit, 180* therm, TB bypass, Gutted CAT, Flowmaster 80 Series Muffler added to Unkown CatBack, Ported Intake
http://www.geocities.com/david_angel_16
Old Nov 27, 2001 | 05:21 PM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
Less deflection with a poly mount. Helps eliminate wheel hop. - Randy
Old Nov 28, 2001 | 06:17 PM
Petes 84Z28's Avatar
Car: 1989 Firebird Formula
Engine: Internal Combustion
Transmission: Completed
Axle/Gears: ones that turn.
Energy Suspension (and others) poly mounts won't seperate in the event of breakage; that'll keep your tailshaft from hitting the top of the drive tunnel when you hit the happy pedal.
One drawback is that some of them (ES for sure..) raise the tail end of the tranny up about ½" which can contribute to vibration coming from the front U-joint.
Pete
Pete
Pete's Place
HiOutput Tech Page
83 SC..former V6...now 216+k mile LG4/5-speed.. 14.891@95.54
Jeremys87
Jul 14, 2022 09:08 PM
customblackbird
Aug 15, 2021 10:16 PM
Elliswon
Aug 10, 2015 12:33 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
NBrehm
Aug 5, 2015 07:57 PM
