scary 2-3 shift
Old Nov 29, 2001 | 03:21 PM
slowV8berlinetta's Avatar
scary 2-3 shift
Irregardless of if the tranny is warmed up yet, the 2-3 shift will be sloppy with a lag long enough to go over redline and my digital tach to flash at me. At least this happens when i'm on it, but there is always a lag between gears. I would like to be enlightened as to what is wrong and how much life is left in the trans. The fluid is still bright pink and up to level- has been so from the day i bought it(3-4,000 miles ago). I believe the tranny to be original, i have the reciepts since 125,000, and i'm at 191,000. I intend on replaceing trans before putting in 350, but would really like to know how long i might have before it explodes.
'84 Berlinetta, LG4, 700R-4, starwars interior, falling headliner, T/A t-handle shifter, trans cooler, open element, more to come in time and $$ www.hipergp@yahoo.com
Old Nov 29, 2001 | 03:31 PM
crucial's Avatar
Do you REALLY think anybody knows how long you have left ? It really is a stupid question. It's obviously about to go. It could work for another day or another decade. Just get it fixed as soon as you can.
1992 Z28 5.7 TPI
ZZ4 longblock
Harland Sharp roller rockers
Accel base and SLP siamesed runners,
52MM SLP Throttle Body
Hooker Headers & Flowmaster catback
MSD6A ignition
aluminum driveshaft
World Class 5-speed
Old Nov 29, 2001 | 04:01 PM
TheWraith's Avatar
Car: 1987 Camaro IROC Z28
Engine: 355
Transmission: 1994 T56
Axle/Gears: BW 3.27 (stock)
it's anyone's guess....there's no formula for when it'll blow up. if it's original though, congratulations, that's the highest mileage original non rebuilt 700r4 i've ever heard of. My roomate made it to 173,000, but he blew his v6 motor, and pulled the still working trans so he could swap to v8.
i'd swap it out of there ASAP, but i'd be just as worried about the motor as you are about the trans for the time being. I blew a motor years ago when my dying 700r4 slipped out of gear and i over-revved the tired motor. If the motor has 190k on it, you'll probably break it hitting redline more than a few times.
Old Nov 29, 2001 | 04:02 PM
transfixleo's Avatar
That really would be hard to answer. It is also possible that someone did a 'home-made-shift-kit' and opened up the 2-3 feed too big. You can then get a cutloose on the upshift. Especially if this has been doing this for a long time like that. A 'Vette Servo in place of a 554 or maybe a 553 could help you out on that. Doing the VB right in the first place is the real answer though.
Old Nov 29, 2001 | 08:54 PM
Jay 727's Avatar
I have home made shift correction modifications, it did cut loose on 2-3 shift until I tightened the 3-4 clutch pack. Stock is .049 to .113. Performance is tighter, mine is now .015 with 7 frictions and it moves my 2900 pound truck with a 365 HP 350 down the quarter in 13 seconds at 107 MPH with no slippage at all (except tires). It's also a fresh rebuild with raybestos clutches and no other aftermarket parts. Been together almost a year now.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
darwinprice
17
Oct 11, 2015 11:51 PM
racereese
Oct 3, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
AmpleUnicorn88
Sep 24, 2015 09:15 AM
