Transmission Question...
Old Nov 30, 2001 | 10:50 AM
adamyeo's Avatar
Hello, I am currently looking to put a different rearend in my 86 Z28, I currently have 2:73's in the rear, limited slip diff. and I am looking to go up to 3:73 with a Posi unit. My car currently has a 350 ci with a 480 high lift cam, and a TR400 Transmission that seems to work well, my question is "is my tranny going to hold up to the power or is now the time to look around at other options?" Now, I need the overdrive or at least a four speed of some kind, I am considering changing over to a manual tranny but that is quite a bit of work, any ideas as to how or where I can get a better transmission that will bolt up and fit right into place? Thanks in advance for your suggestions.
Old Nov 30, 2001 | 11:32 AM
82camaro's Avatar
Car: 82 camaro SC
Posi=limited slip. limited slip=Posi.
If you want to stay automatic, a 700r4 from pro-built would probably work nice.
350 with stealth intake, holley carb, 470 lift cam. 700r4 with .5 boost valve, vette servo, tci lock-up kit, B&M megashifter. Richmond 3.73 gears, powertrax locker, timkin bearings, synthetic lube. Custom 3 inch single into 2 2.5 pipes. 1 1/2 drop springs, 1 5/16 solid front sway bar, 1 inch rear bar, custom subframe connectors, custom LCA relocation brackets. Kobel ground FX, currant red metallic paint. Lots of other stuff...
82camaro
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Youngs92
Sep 23, 2015 11:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
