Dexron VI in T-56??
Old Aug 24, 2009 | 01:33 PM
livewire's Avatar
Car: 1983 Z/28
Engine: Edelbrock 355
Axle/Gears: 3.42/Zexel/PBR
Dexron VI in T-56??
I've got a gallon of Dex VI and was wondering if its acceptable to use it in a BW T-56? my trans is a 95 model and has the Dex IIE tag on it. I know dex II superceded to Dex III and you can use the VI in place of the III. Only reason I ask is it says on the back of the jug not for use in manual trans applications. I can't see how it would hurt since its just a better blend but figured i'd ask for anyone else's insight before I pour it in. Thanks.
Old Aug 24, 2009 | 03:41 PM
85MikeTPI's Avatar
Car: 1985 Camaro Z28, VIN F
Engine: 427 sbc, HSR
Transmission: T-56, self rebuilt 700+ hp
Axle/Gears: Moser 12bolt, 3.42 trutrac
Re: Dexron VI in T-56??
Has your T56 ever been rebuilt? Some of the newer lubes are not compatible with the older fibre friction rings in the pre-98 Fbody T56s. The rebuilt kits all come with the newer carbon-fibre rings and would be more compatible..
IMHO, I wouldn't take the chance to save $5 and risk a $500+ rebuild.. Use plain old Dex3 or Mobil1 ATF in your T56 and you won't have to worry..
Old Aug 25, 2009 | 03:16 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
I tried mobil 1 atf in my fresh T56 with the carbon fiber rings and it just didn't work out so well. I went back to plain old dex and it shifts much better, no "notchy" shifting now. And it semed like there was a kind of break in period for it. After about 5000 miles my trans seemed to really free up a lot and its a dream to shift now. I was concerend that I'd done something wrong building it, but the switch from synthetic to reguler dex really made a difference in the trans. And it seems to be a lot quiter than everyone here says they are.
I'm sticking with plain dex for now. It works well, no reason to mess with it.
Old Aug 25, 2009 | 08:17 PM
85MikeTPI's Avatar
Yeah, you don't want to break in a new rebuild with Mobil1, just like a motor rebuild. I recommend 500 stop&go miles on regular DexIII, then switch to Mobil1 after that if you like.
88SS6SPEED
Nov 11, 2015 07:05 AM
tonys91rs
Oct 10, 2015 03:31 PM
Hello, Michael
Aug 20, 2015 03:19 PM
cRoe4
Aug 7, 2015 08:46 PM
Dave M
Oct 19, 2001 07:59 PM
