FLEX this!!!
FLEX this!!!
Alright here is my deal. I have no clue what number of teeth flex-plate I have on my 89 Formula 350? I need to order an new one to stop the grinding I hear and the lag I experience when the engine reaches 3500 rpms. Kind of feels like the trans dropped out of the car when it hits that high an rpm. So anyone know what type of flex-plate I need? I could use the help, Thanks!
Transmission: 4L80E/4L80E
You need a 153-tooth, one-piece rear main seal flexplate.
Assuming the flexplate is causing the problems you describe. The grinding I'll assume is when the starter is engaged - that's typically a starter shiming problem (has the starter been replaced?). The "lag" at 3500 rpms - can't imagine how that could possibly be caused by a flexplate. Low fluid, maybe.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R4, 2300 stall TC. Ported World 305 heads, Crane PowerMax 2050 cam. ZZ3/4 intake, oil pump, pan & baffle. Accel HEI SuperCoil & module. Hooker 2055 headers, 3" Catco cat & 3" catback w/dual-opposite Flowmaster 80. 2.93 limited slip. Spohn SFCs waiting to be installed. AMSOIL syn lubes bumper-to-bumper. Daily year-round driver. Best ET, speed TBD...
57 Bel Air, my 1st car. '66 396, 9.7:1 forged TRWs, Weiand Action+, Holley 750VS w/4150 conversion, GK 270 cam, Magnum rockers, Jacobs Omnipack, 1-3/4" Hedders & 3" Warlocks, TH400 w/TCI Sat Night Special conv & Trans-Scat shift kit, MegaShifter, 3.08 8.2" 10-bolt w/Powertrax, AMSOIL syn lubes bumper-to-bumper. Idles smooth @ 700 RPM in D. Best 15.02/95.06 @ 5800' Bandimere (corrected 13.93/102.4 @ sea level).
codeysabatini
Nov 10, 2015 04:07 PM
New2Chevy
Sep 28, 2015 12:35 AM
