Question for the Mustang Guys!
Old Nov 29, 2001 | 02:15 PM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
I know there are several of you guys on here who seem fairly knowledgeable & open-minded so I figured I'd post this here first. My roommate is in the process of purchasing a 92 5.0 LX automatic. The car is bone stock & in awesome shape but he wants to make it a health street car/daily driver. How hard is it to convert to a 5-speed? I know the driveshaft is interchangeable but is the 5.0 & 2.3 stuff interchangeable, such as linkage etc.? Or would he be better off keeping it as an auto & adding a stall converter & shiftkit. The car does have 120K on it so the auto would probably need a rebuild if adding the converter. Any help you guys can give would be greatly appreciated!
'91 Z28 1LE; 355, Sportsman II heads, Edelbrock TPI w/ 58mm TB, Tremec TKO 5-speed, 3.73's & much, much more
[This message has been edited by Ed1LE (edited November 29, 2001).]
Old Nov 29, 2001 | 03:08 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
if i were u i would take a 429scj, pound the shiiittt out of the fender wells and drop a 4 speed, new rear and all the goodies. screw the 5.0! it aint **** anyway
86 berlinetta
350cui w/.30 over
.526 hilift cam
hooker supercomps
3" duals
edelbrock streetmaster
holley 750 dp
bad asshauler
Old Nov 29, 2001 | 04:04 PM
transfixleo's Avatar
IF you do stick with the AOD auto, you MUST use the TransGo Reprogramming Kit or you will repeatedly go through trannies. If you aren't already on it go to:
http://www.fordmuscle.com/boardpower/boardpower.cgi
Old Nov 30, 2001 | 11:11 AM
Ed1LE's Avatar
Engine: 5.7, 5.0
<font face="Verdana, Arial" size="2">Originally posted by spartyon:
</font>
Heh, yeah but we're on a budget here!
[This message has been edited by Ed1LE (edited November 30, 2001).]
Old Nov 30, 2001 | 03:36 PM
FstBrd6point3's Avatar
as far as 2.3 and 5.0 stuff being interchangeable, you prolly don't wanna do that. The 2.3 is a p***y engine, and any tranny parts would be torn apart by the 5 liter, not to mention I don't think they share the same parts. as for going to a 5-speed, it takes some work, U need to by the tranny, the clutch assembly, the petal assembly, which is actualy quite expensive, even used, and all he miscalanious (sp.??) parts to go along with it. If I were you, I would try and find some one selling a recently re-build aod or c-4, c-6 and just put a better converter in it. When my bro blew the tranny in his T-Bird he got a very nicely built aod from a 450 h.p stang for 250$, thing shifts like gold, and it takes all the abuse my bro throws at it, which is alot. If you want better information, go to www.corral.net just like thirdgen.org, only for stangbangers, good luck
1987 Pontiac Firebird Formula 350
1 of 2,384 made, Black with Silver decals
350 TPI
700R-4 Tranny with TCI shift kit and Corvette servo with TV boost sleeve
TCI saturday night special 2200-2500 stall converter
WS6 supsension
SLP headers with full 3" exhaust exiting through an SLP dual 2.5" tip muffler
SLP airfoil
180 degree thermostat
hypertech "performance" chip
3.73 rear
Viper talkin alarm with remote start
My 383 is in the process of being built right now, hopefully to make it's debut by middle December. . . many more mods to come in the summer. . maybe some experimentations with juice. . have some track times my independence day.
Old Dec 1, 2001 | 02:35 PM
85cam's Avatar
Car: 92 RS
Engine: 396 sbc
Transmission: t5
The tranny will work but you have to get a different bell housing
I have seen the 4 cylinder trannys run 12's in the quarter
Just have to know how to drive!
Old Dec 2, 2001 | 04:01 PM
bottlefed89's Avatar
i would probably just have the AOD built up they are more consistant at the track and will handle the abuse better then a T-5 would after time the syncro s in the 5 spd will take a s**t even under stock power unless you have the $$$$ for a tremec or something stronger stick with the AOD
MustangBeater20
Oct 29, 2022 09:20 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
redmaroz
Aug 16, 2015 11:40 PM
Street Lethal
Aug 14, 2015 08:25 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
