need help with rear end
Old Aug 25, 2009 | 02:11 PM
lillis375's Avatar
Car: 1989 Camaro
Engine: 355
Axle/Gears: 9 bolt 3.45
I have an 89 camaro with a 350 that i put in. i have a posi rear with stock 2.73 gears in it now i was wondering can i just upgrade my gears to 3.42 or what i should do i can't get a 12 bolt or 9" right now cant afford it and i want to start driving this before i leave, all help would be great thanks
Old Aug 25, 2009 | 02:14 PM
big gear head's Avatar
Re: need help with rear end
You can get a special thick 3.42 that will fit the 2 series differential that you have now. They are slightly more expensive than the standard 3.42, but saves you the money of getting a 3 series differential. You will also need a good installation kit and the knowledge of how to set it up correctly.
Old Aug 25, 2009 | 02:26 PM
lillis375's Avatar
Car: 1989 Camaro
Engine: 355
thanks now would it just be easier to get a 4th gen rear with the 3.42 gears and swap them out? thanks again
Old Aug 25, 2009 | 02:33 PM
It would be easier, but you might have some tire clearance issues. The 4th gen rear end is wider.
Old Aug 25, 2009 | 02:45 PM
lillis375's Avatar
Car: 1989 Camaro
Engine: 355
I dont think that will be a problem i have corvette rims and right now i have the 2 in adapters and i would need those for the rear with a 4th gen right? i just dont know about how far they will stick out they have 275/40/17 on them
Old Aug 25, 2009 | 03:14 PM
You should be able to leave the spacers off with the 4th gen rear end. That might work out just right for you.
Old Aug 25, 2009 | 03:22 PM
lillis375's Avatar
Car: 1989 Camaro
Engine: 355
thanks i think that they way i will go they seem pretty cheap on ebay
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
