700r4 delayed hard shifts
Car: '91 gta
Engine: 350 c.i. s/c
just picked up '91 gta w/6-7psi vortec s/c...took to track, and was disapointed with the tranny big delays between 1-2nd gear then hard shift when it did go...shifting manually of corse 1-2 ten sec. between shifts cable is tight at wot? any ideas where to start? thanks
Car: '91 gta
Re: 700r4 delayed hard shifts
after reading other posts, I think my problem is in the tv cable or clogged throttle valve? the long delay between hard shifts...was very disapointed with car was told mid 13 car ran only 14:20 at 98mph but i know the tranny thing cost me a few tenths..I gotta go thru car call vortec and measure pulley to see how much boost its suppost to be?? ran like 3-4 psi not 7-8psi? got all winter to get her going probley send s/c out for rebuild..either way cars cool, always loved the '91-'92 gta's...just want it to run as good as those ls1 t/a's...will see...thx
Car: '91 gta
the tv is pretty tight at wot so maybe that aint my problem? bought the car w/the s/c so dont know if that effected it and how it would?? maybe at boost the knock sensor messing with it? any ideas willbe apeciated..car only has 53k miles, tv clogged? fluid looks good..should i change to the b&m shift fluid? thanks
Hotrodboba400
Dec 10, 2019 07:07 PM
TheTraut88
Sep 7, 2015 05:22 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
