8.8 rear posi ??????
Old Aug 25, 2009 | 06:42 PM
graymaro87's Avatar
Car: 87 Z28
Engine: 305 4bbl
I am wondering if any one has done, or knows where to find the information to swap the GM 10 bolt to a ford 8.8 rear posi unit... i know some of you might be offended by this thread, and i appologize for that... its just some manufactors do it better than others.. i believe that the 8.8 and the 9" is a very strong and reliable rear end..... plus im parting out cougar and it has a Built 8.8 with 373 gears....
any help guys/gals
Old Aug 28, 2009 | 07:51 PM
graymaro87's Avatar
Car: 87 Z28
Engine: 305 4bbl
Re: 8.8 rear posi ??????
NO BODY!!!!
Old Aug 28, 2009 | 09:49 PM
big gear head's Avatar
https://www.thirdgen.org/forums/tran...ord-8-8-a.html
Maybe this is what you are looking for.
Old Aug 31, 2009 | 11:13 AM
Shagwell's Avatar
Car: projects.......
I would guess you're not getting much response due to your wording. It's hard to decipher what you are wanting to do.
If you're talking putting a complete 8.8 under your f-body, then the thread link above should get you a considerable amount of the info you're looking for.
It is very difficult to swap rears under these cars due to their unique suspension system.
Old Sep 1, 2009 | 11:58 PM
graymaro87's Avatar
Car: 87 Z28
Engine: 305 4bbl
Yes i was wanting to swap out the stock original rear end and install the ford 8.8" rear end. the rear end was off of a 89-93 thunderbird supercoupe.. i had it installed on my 94 cougar for 2 years until the motor blew. i was just trying to be resourseful and use it on my 87 z28. It seems like a pretty detailed, complicated swap. however the winter is approaching and it would be a project for then. i have a complete rearend/suspension, rear brake set up. it sounds like that would be needed. i just dont to like the fact of the ford bolt pattern though... IDK. im sure the answers will come
Old Sep 1, 2009 | 11:59 PM
graymaro87's Avatar
Car: 87 Z28
Engine: 305 4bbl
shagwell, i like your quote BTW..
Old Sep 2, 2009 | 10:29 AM
Shagwell's Avatar
If your axles have full faced flanges(no extra holes besides the studs) you can have them re-drilled to the GM 5x4.75. I have done a set in a drill press by using a dual pattern wheel to align the holes. It's a time consuming process and requires a couple good drill bits(must be done in steps up to size); axles are very hard material.
The control arms and spring perches are the easy part, getting the tq arm mounted solidly/securely is very difficult.
Old Sep 3, 2009 | 09:29 AM
nomind's Avatar
Car: 85 Trans Am
Engine: LB9
Transmission: Finally Fixed (T5)
If I'm not mistaken, the 89-97 Thunderbird, and Cougar came with IRS, not a live axle setup, I've owned three of them, so I'm pretty sure. If you want to go that route, you've got a lot of work ahead of you.
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
