Hard Shift
Old Dec 5, 2001 | 04:50 PM
1MEAN92RS's Avatar
Car: '92 Rally Sport
Engine: LO3
Hard Shift
I have a '92 RS (700R4) w/ 113K on it. When I'm sitting in park at idle (even after it has dropped out of fast idle) if I shift directly into 2nd it is a REALLY hard shift and she wants to lurch forward even with my foot on the brake. The trans fluid is at the right level. I know this can't be normal because my brother's '88 IROC does not do this. Is this a sign of a bigger problem? Any ideas?
Old Jun 1, 2003 | 07:17 PM
Chuck Haynes's Avatar
My car is having the same prob. Did you ever figure it out???
Old Jun 1, 2003 | 07:21 PM
TekViper's Avatar
Car: 1990 Pontiac Firebird
Engine: 3.1L v6
Transmission: Automatic
mine does that too. from park to drive/od it jerks a little, but from park to 1st its a bigger jerk.
Old Jun 6, 2003 | 10:40 PM
Anyone? Could this be that the TV Cable is too short?
Old Jun 8, 2003 | 08:54 PM
25thanniversZ's Avatar
to much throttle pressure in the valve body......happens alot in 700's wether in cars or trucks.
check ball in valve body is hanging in the secondary channel....trash or somthing will cause this....manualy shift and dog the **** outa it...I mean drive it hard
Old Jun 9, 2003 | 04:38 AM
Pro Built Automatics's Avatar
Does this happen when you put it into "D" or "OD" position?
Old Jun 9, 2003 | 12:46 PM
Adam Jones's Avatar
My 700r4 does the same thing. I always assumed it was the small shift kit I had put in combined with the idle RPMs. (750)
It shifts REAL hard from neutral to drive or OD, and almost as hard from park to drive or OD. I have to drop it into reverse, then quickly slip it into drive or OD to lessen the slam. There is also a substantial lurch when i drop it from OD into drive starting around 20+ mph. That can't be good for my U-joints.
Is this shift kit design, or did they build something incorrectly in my tranny?
-Anthony Helton
junior419
Apr 7, 2025 11:35 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Breazlan
Sep 25, 2015 11:20 AM
TheTraut88
Sep 7, 2015 05:22 PM
