What is my best bet for a rear end swap?
Car: 91 Firebird
Hey guys, well here it is, I want to put in a posi rear end with lower gears but do NOT have a lot of money to do it, what's my best route? Did the V6's ever have posi? I've been told to get the rear end out of a V6 in the junkyard, good idea? I'd like 3.42's but 3.23's would be ok, I could always upgrade to 3.73's later right? Please help me out, I'm confused.
Car: 4
Engine: 6
Transmission: 5
V6 cars often have good gears but NEVER have posi from the factory.
Cheapest way would be to get a 91-92 6-cylinder rearfrom the boneyard, which will have drum brakes
, and maybe a good gear; then get the SLP posi for $99 and stick it in there. If you don't mind the drum brakes, that is the best possible setup for the least possible $$$.
ICON Motorsports
, and maybe a good gear; then get the SLP posi for $99 and stick it in there. If you don't mind the drum brakes, that is the best possible setup for the least possible $$$.------------------
ICON Motorsports
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
V6 never had posi? I got my 3.27 posi disc rear out of a 89 V6 Firebird. Maybe its not stock but why would someone waste their time and install a posi-rear into a V6? Must be stock...
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Were they even still using the 9 bolt (that's what has 3.27 gears) in 89?
I also would have to say it was swapped in, and would wonder why a posi 9 bolt in a v6 car, unless it was a built-up v6. Is it disc brake?
Working on:
'84 Z28 LG4 305 with 209,000 original miles!
Dual electric fans (from a formula).
9 bolt posi disc rear with 3.27 gears.
145 MPH IROC Speedo
430 HP 350 (ZZ430) Coming soon! (Building it myself, so I don't get those AWESOME valve covers!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
+ L1 Advanced Engine Performance
+ X1 Undercar Specialist
And....A sig. that's getting way too long!
Working on:
145 MPH IROC Speedo
Car: '89 IROC-Z
Maybe they didn't come stock but this bird had one. Its an austrialian 9-bolt, posi, disc, and definately 3.27. In my book it says 1989 came with 3.27 posi but I never bothered looking at the code on the axle cause I know its 3.27 and I know its posi.
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
