rear axle problem
Old Dec 6, 2001 | 02:35 PM
383-Z28's Avatar
rear axle problem
I have an 85 with a 3.08 gear 10-bolt in my 84 camaro. When driving the drivers side wheel tends to wobble a bit. It is not the rim and the bolts are not loose. Is the axle inside the housing bent or warped and can they be replaced?
Old Dec 6, 2001 | 05:05 PM
92RSFivePointSlow's Avatar
Car: 2002 Harley Nightrain
Engine: twin cam 88ci
Transmission: manual
Raise the wheel off the grouund and see if you can wiggle it. Some in and out play is to be expected(minimal). But if you can wiggle the wheel then your bearing is shot. If it's solid, then you could have a bad wheel or tire. Try switching both your rear wheels and see if the problem moves to the other side. If not, then I'd say you'r axle is bent. You can pick up a whole new pre-1989 rear for $100 at a junk yard, and steal an axle out of it. -Randy
Old Dec 6, 2001 | 10:00 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Sounds like the axle is bent... very typical curb damage, the flange is not perpendicular to the shaft any more.
Yes they can easily be replaced, ordinarily takes less than ½ hour from drive-in to drive-out.
ICON Motorsports
[This message has been edited by RB83L69 (edited December 06, 2001).]
customblackbird
Aug 15, 2021 10:16 PM
ZMWojnar
Brakes
May 12, 2019 10:43 PM
draco
Oct 4, 2015 09:25 PM
E Rod
Aug 28, 2015 05:17 AM
red90IROCls1
Aug 25, 2015 06:56 AM
