What gears do I have?
Old Dec 6, 2001 | 07:09 PM
brian89transam's Avatar
'89 Trans Am, 305tpi, auto trans, limited slip rear, 15" wheels, drum brakes in the rear. It's got a PERFORMANCE SUSPENSION badge on the passenger side dash if that means anything.
Thanks a lot
-Brian
Old Dec 6, 2001 | 09:36 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
2.73, most likely, unless they've been changed or something else was ordered when new.
You could always pull the diff cover and verify.
Old Dec 6, 2001 | 11:08 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Scrape away the rust and grease on the front of the passenger side axle tube near the housing and read the code. Then look up the code in the tech data section. That is what originally was originally in the car (and probably still is).
Miles
88 427 Big Block Camaro
(Best 1/4) 12.18 @ 113mph 1.75 60ft
(Best 1/8) 7.76 @ 94mph 1.72 60ft
Currently installing 3.73's into my 9 bolt (YES, it is a 9 bolt & YES they are 3.73's, not 3.70. I currently have 4.10 gear sets and new series 3 posi carriers for sale for 9 bolts )
www.koolmeister.com
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
