which is stronger - stock '84 disc rear or stock '84 drum rear
Engine: LG4 / turbo LQ4
Transmission: 700R4 / 4L80E
i tried searching, but couldn't find the answer i was looking for. i'm restoring a 1984 Trans Am and am not sure which rear end to use. i have two rears to choose from. both are from '84 Trans Ams and are stock. one is a posi disc, one is a posi drum - i believe they are both 3:23 ratio. i have the master cylinders and prop valves for each.
is one of these rears better than the other to use? my car is going to be a quick street car with maybe 2 visits to the track each year. i'll eventually be running a 350 engine with about 400hp at the rear wheels. i know there's much better aftermarket rears, but i won't be able to afford that for awhile.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: which is stronger - stock '84 disc rear or stock '84 drum rear
I would think rear axle strength is the same, they are both same splined axles - ust different braking systems attached on the ends
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Both have 26-spline axles. No difference in strength. The following FAQ may provide some useful info:
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
JamesC
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Forget about the brakes and pick the one that is in better shape. They're exactly the same.
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
As far as the brakes go,i'd be tempted to go with the
drum-i've used both and have found the drum to be
more reliable,lighter,and just as effective as the pre-89
disc setups with their clumsy,clunky,leak-prone calipers.
Also i'd say the drum has better pedal feel.
mine has discs now(they do look cooler)but i might
switch back to drum later.
The Delco-Moraines have a bad reputation on the board, but with the "fit" kit in place, they seem to function well--at least mine did.
Here's the recall:
http://members.shaw.ca/crussel/recalls/86c28/86c28.html
JamesC
Here's the recall:http://members.shaw.ca/crussel/recalls/86c28/86c28.html
JamesC
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Just for an extra measure you should have the axle tubes welded. I know a guy that knows a guy that knows a guys sisters,brothers,uncle that can do it for you. Let me know.
3rdgenparts
Aug 6, 2015 09:03 AM
