auto tranny shifting early...why?
Car: 85 Trans Am WS6
Engine: 305HO L69
my car has an lg4 and 700r4. if i get on it hard from a stop, it will stay in first gear until 4500 rpm, then it shifts. however, it will only stay in 2nd gear until about 3700-3800 rpm, then it shifts to third, even if i have the pedal to the floor. why does it do this? i've had the car for 2 years, and it's just started to do it the past few months. also, when i first got it, up to like 55mph, if i put the pedal to the floor, it would drop down to 2nd gear. now it won't downshift to 2nd when i'm doing over 45mph. i'm assuming this is the same problem, but what is it? would a b&m megashifter solve my problem?
87 Camaro LT
bone stock lg4 w/ 700r4
1/4 mile: 35 seconds @ 50mph (or so it feels like it)
mods:
ground effects (in progress)
93 camaro seats (installed)
99 camaro center console (in progress)
85-87 iroc or 91-92 z28 rims (91-92 installed)
white 145mph iroc gauges (in progress)
87 Camaro LT
mods:
Adjust the TV cable as per transfixleo. It has been posted several times on this board. This should solve the problem, if not you would want to install the Trans-Go Shift kit or the Performance Shift kit to remedy this and other inherent problems in the 700R4. On second thought, I would do this anyway as I am sure you would like the results.
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
