Definitely looking at Trans-Go shift kit, but
Old Dec 9, 2001 | 10:09 AM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
had a ? about a kit that you can manual shift? I don't know ... just looking around. My car will shift fine while cruising around, actually, seems like it's shifting a bit early, but when i get on it, it won't shift until 7000RPM if I just stomp on it. I find myself letting off on the gas so it'll shift. That's not good. If I can control the shift myself, that would rock. Will the Trans-Go fix this kind of problem or should I look elsewhere?
Old Dec 9, 2001 | 07:11 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
BTT
Old Dec 9, 2001 | 07:31 PM
nsimmons's Avatar
the transgo kit with the stick shift option will allow you to do this. You must make every shift, and it will allow you to start in other gears at a stop (not a good idea), its on my list of thinsg to do. Other choice is to use a govenor sping and weight kit to lower your shift points..this will retain the auto function.
1984 Z51 Auto, Ported and polished intake, K&N, MSD, Ram air/Cold air intake, no cat, no AIR, no egr, no swirls plates
Old Dec 9, 2001 | 08:28 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
If you install the TransGo "stick shift" option, thats it. It will be a clutchless manual. I don't think its a great idea for a daily driven street car. You must MANUALLY make every shift. If you come to a stop, you must put it down into 1, then kick up to 2, then 3 and so forth. If you simply put it in 3rd "D", you will take off in 3rd gear. It may be fun at first, but I'm sure it gets old fast. Just may want to consider that.
If you live in Southeastern US, check us out!
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Old Dec 9, 2001 | 08:45 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Sounds like you need to adjust govenor/tv to get your shift points right, or use a Trans-go recalibration kit. I agree that the full manual would get old!
Old Dec 9, 2001 | 11:55 PM
nsimmons's Avatar
i dont get these people who say a full manual would get old. Ive owned mostly stick cars before and they never got "old" i was forced into the damn auto by circumstance, and putting a stick in it isnt feasible. I've also invested to much time and money on restoration to sell it for a stick car.
Old Dec 10, 2001 | 06:01 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Honestly, I can't put a finger on exactly what it is, but I just don't like it. I have driven many stick cars, and I currently have a 5-speed firebird, and I absolutely LOVE rowing through the gears, but when I manually shift my Trans Am equipped w/ the automatic trans, it just seems annoying after awhile. Its just not the same as having a manual tranny IMHO.
South East Thirdgen
1987 Trans Am 305
14.88 @ 92.81
Old Dec 10, 2001 | 08:51 AM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
I looked at pro-built.net and they don't list a manual kit. I don't drive the car that much so it wouldn't matter. I can understand GMTech tho. I think I may just leave it automatic if I can get the damn thing to shift right. If not, nothing better than controlling the damn thing yourself, you know? hehe
Who else sells Trans-Go shift kits?
Old Dec 10, 2001 | 01:49 PM
Pro Built Automatics's Avatar
The kit that I carry offers the "full manual" or "full automatic" setup.
Hope This Helps!!!
Old Dec 10, 2001 | 02:13 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
Thanks!
Is that the Heavy Duty kit? I'm also looking at just getting the .500 main and .296 intermediate & corvette servo components for $40 something. Would this be fine or would you recommend just getting the kit? Could I get the .500 main in the Heavy Duty kit or would I have to order the street/strip kit?
Old Dec 10, 2001 | 03:15 PM
The Street/Strip kit with the .500 main boost valve, .296 intermediate boost valve, & Corvette servo are what you need to the job you want. The cost on this kit is $124.27 as of the moment.
Old Dec 10, 2001 | 04:06 PM
Allan's Avatar
Car: 1988 IROC-Z
Engine: 5.7L TPI
Axle/Gears: BW 2.77
Alright, then. Looks like I'm spendin some Christmas money!
Old Dec 11, 2001 | 06:12 PM
transfixleo's Avatar
You will want to recalibrate the Governor. I doubt if it really gets to 7000 RPM. If it does then you have some other "issues" to deal with along with it!
The full manual operation of an auto unit is nothing like a standard because you cannot slip the clutch. Trust me, I have driven this setup and it gets old in about one day. Also, if you forget and take off in 3rd or 4th it's time for a rebuild. Do you really want to risk that?
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
