converting speedo from mechanical
Old Sep 6, 2009 | 08:02 PM
91rscamarodm's Avatar
i have a 91 rs camaro with a 700r4 the orignal trans was replaced with a 700r4 from a 86 camaro the trans had a mechanical driven speedo and my 91 is an eletric system is there conversion kits of can i convert it with the parts i have. thank you
Old Sep 6, 2009 | 08:47 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: converting speedo from mechanical
Maybe just bolt the tailshaft from the 1991 tranny onto the rear of the 1986 tranny?
It's not just the tranny issue, but your instrument cluster as well, since it's also electrical a mechanical speedo unit would have to be swapped into your cluster.
Old Sep 7, 2009 | 06:58 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Welcome to TGO. A search here will often provide the info you're seeking.
Here's a link to start you off:
https://www.thirdgen.org/forums/elec...ml#post4275417
JamesC
Old Sep 7, 2009 | 07:55 AM
Car: 1992 RS
Engine: Carbed 350
So according to the link JamesC provided, if I'm reading it correctly, maybe you can just swap speedo housings on the trans rather than the entire tailshaft housing - which would be much easier. When I swapped speedo gears for a new rear end, I never looked close enough to see that the speedo gear housing will seperate off the tailhousing, but it makes sense.
GTAman
Jul 3, 2024 07:29 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
jtwoods4
Sep 3, 2015 05:39 PM
andy74
Sep 3, 2015 08:41 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
