Whats Better. M-20 or T-56
Car: 87 Iroc
Transmission: T-5 3.42's
Im going to get a new tranny for my 87 iroc.
I have 350 HP.
My t-5 cant take it.
I want a Muncie M-20 or a T-56. Whats better and why?
I have 350 HP.
Both are strong enough.
Muncie - Cheaper???, easy bolt it, no overdrive. About a 6 on the WOW factor.
T-56 - Costs more???, more "engineering" to bolt in (espically for a clutch fork), 2 overdrives. About a 9 on the WOW factor.
If you have <3.08 in the rear, Muncie will be fine.
If you have >3.73 in the rear, you'll like the overdrive.
[This message has been edited by a73camaro (edited December 12, 2001).]
<font face="Verdana, Arial" size="2">If you have <3.08 in the rear, Muncie will be fine.
</font>
</font>
3.73 and over , go for the other one.
there's no replacement for displacement
1986 IROC 5.OL auto w/posi
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
Muncie's will hold up better, cause they were strapped to factory torque monsters
1989 Camaro RS, 355 engine, 4 bolt block, 11.5:1 compression, 305 heads--ported, polished, milled, 3-angle valve job, 2.02 intake and 1.60 exhaust valves, Edelbrock rpm valve springs, 1.5 rockers--, Keith Black pistons, solid lifter cam, Edelbrock RPM intake, 750 cfm Holley, Holley Red electric fuel pump, MSD distributor, Turbo 350 w/B&M Shift kit, 3.73 Richmond Gears, Hooker headers, Flowmaster exhaust
My Pontiac's (my babies)
1972 Pontiac LeMans, 2 Door, red with tan top, 350 V-8, Edelbrock Perf. Intake, Rochester Carb, Turbo 350 trans with B&M shift kit, Dual Exhaust
1968 Pontiac GTO, Rust free body, White with Black Interior, Original 4-Speed Car, 400 V-8 engine, Hideaway Headlights, Positraction Rearend
i just bought the tremec t56 from darkhorse performance $1899.00 it bolts to t5 bellhousing i ordered the spohn torqe arm and crossmember for another 400 putting in next week ill let you know what i think. my rear is 3.27 posi with disc's. running about 350 - 380 hp maybe more need dyno run.i always wanted 6 speeds..oooooooh yea can't wait
88SS6SPEED
Nov 11, 2015 07:05 AM
tonys91rs
Oct 10, 2015 03:31 PM
Hello, Michael
Aug 20, 2015 03:19 PM
