t5 manual transmission help
Old Sep 9, 2009 | 01:58 PM
caifan2k's Avatar
helo i need to know before i move on to the project i have a 87 trans am tpi with manula transmission and ive been thinking for a while in swaping a vortec5.7 engine and posiibly puting a 75-100 shot nitrous will the tranny hold or is there any alternative tranny that will that wont be to costly what about the rear end im triying to stick with manual tranny. thanks
Old Sep 9, 2009 | 08:29 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Re: t5 manual transmission help
It will hold if you drive it gently...and 100 shot doesn't fall under "gently".
Old Sep 10, 2009 | 03:38 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
You should consider a T56 swap. Will run you about $2000, but you can offset that cost by selling your T5 setup. I got about $500 for my trans which brought the T56 cost down considerably.
See the T56 sticky at the top of this forum for info on the swap.
Hotrodboba400
Dec 10, 2019 07:07 PM
angel2794
Sep 8, 2015 06:22 PM
scottmoyer
Sep 7, 2015 07:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
