700R4 just broke
Car: 86 Z28
Axle/Gears: 3.42 posi
700R4 just broke
So I was coming home from the gas station and my car wasn't going into overdrive. I get it home and check the fluid and it is a little low but not enough for it to not shift. Then there is smoke everywhere and i look and the cat is covered in tranny fluid
I get the car on a jack and see that the case is cracked where the servo cover retainer is
I did just put a shift kit in here but it worked perfectly. Just wondering what you guys think happened??
Well the car is going to be parked now, winter was coming anyway, and i think i want to put either a 5 or 6 speed in it, and if i go that far might as well put a 350 in thats just laying around the garage
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
Re: 700R4 just broke
Sorry to hear, but I have a 700R4 if you are interested. I swapped in for a T-56 and its sitting with my 305.
Car: 86 Z28
someguy25thz, thanks for the offer but i may be able to just put a bracket over the cover to hold it in place, or save up for the t56 swap myself...
sjorgens
Oct 1, 2015 07:54 PM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
