Pinion Tail bearing
Old Sep 17, 2009 | 08:47 AM
JPhillis's Avatar
Car: 1992 Camaro
Engine: 350 .030 over 298 cam 9.1 Flat tops
Transmission: T5 swap complete
Axle/Gears: 3.73 posi the 4.10s are history
Pinion Tail bearing
Does anyone know if you can purchase a pinion tail bearing individually and does anyone have a part number. All i can find is complete kits. I would like to purchase 2, one for set up and one for final assembly.
Old Sep 17, 2009 | 10:19 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Pinion Tail bearing
Any decent auto supply store will have it. CarQuest, NAPA, Rockauto, etc.
RBob.
Old Sep 17, 2009 | 12:09 PM
big gear head's Avatar
What are you calling the tail bearing? The pinion gear in the rear end has an inner and outer bearing. The inner bearing is the one next to the gear head and the outer one is next to the yoke. They can be purchased at auto parts stores or at bearing supply stores. I DO NOT recommend using bearings made in China. Many auto parts stores carry these bearings now, so take it out of the box and check it before you pay.
Old Sep 17, 2009 | 01:12 PM
JPhillis's Avatar
Car: 1992 Camaro
The tail bearing opposite of the head bearing. Most all the auto parts stores now have hire complete idiots that don't know their *** form a hole in the ground and just want to sell kits. I was hoping someone may have the Timkin number so I could order the specific bearing.
Old Sep 17, 2009 | 03:47 PM
What rear end are you working on? Is it a 7.5, 7.75 or something else?
Old Sep 17, 2009 | 03:49 PM
JPhillis's Avatar
Car: 1992 Camaro
Factory 7.5/ 7.625
gord327
Oct 3, 2015 01:25 PM
gord327
Sep 29, 2015 10:18 PM
