700r4 or th350????
Old Sep 21, 2009 | 08:19 AM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Transmission: 700R4,700R4
Axle/Gears: LSD,LSD
700r4 or th350????
i cant decide if i want to run a 700 or a 350...the car will just be used to beat on..could careless about gas mileage...i have both transmissions...just stuck on which one to go with??? pro's and con's of each??
Thanks, Jesse
Old Sep 21, 2009 | 08:28 AM
Shadow Z's Avatar
Car: Lots of 'em
Re: 700r4 or th350????
If a manual is not an option, definitely go with the 700R4, I've seen a lot more used in drag racing, and from the looks of the after market, there's a lot more people involved with building 700's.
Plus the overdrive isn't too bad either..
Neither of the transmissions necessarily have "cons". They're both nice and strong automatics, capable of being built to handle monstrous amounts of power.
Heck if it was my car, T-56 all the way. I personally can't wait to get rid of my 700R4, automatics are just too boring, it's nice to grab some gears once in a while.
Old Sep 21, 2009 | 11:13 AM
jak2908's Avatar
Car: 89 RS,89 iroc
Engine: 5.0,5.0tpi
Axle/Gears: LSD,LSD
the manual option i was thinking of would be a muncie 4 speed...
Old Sep 21, 2009 | 03:17 PM
zraffz's Avatar
Car: 1987 Camaro
Engine: LQ9
Axle/Gears: 4.10
Horrible transmissions, atleast in every truck I ever drove that was a 4 speed Muncie it was grind 'em to find 'em.
If it's a stock motor and you are set on using a manual, just use the T5.
I think the TH350 is a stronger trans from the factory, but my heart is set on the 700R4s, and like the person above me said their is enough of a community backing them to make them just as strong if not stronger then the TH350. I would personally use the 700R4, the gearing is a little better and you have overdrive.
Old Sep 21, 2009 | 03:26 PM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
Would need a different cross member and drive shaft for the TH350. OD is nice to have in case you decide to go anywhere with it and has the lower 1st gear.
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
