tranny poly mount worth it
Old Sep 25, 2009 | 10:56 AM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
im debating weather or not to get a poly tranny mount... ive heard that it causes some issues... what kind of issues are there with this.... i have a probuilt 700r4 thats shifts really hard when you give it alot of gas and i have a freshly built hotcammed 355tpi and i dont think the stock rubber will hold up..... what are the pros and cons of using a poly mount... thanks in advance...
Old Sep 25, 2009 | 12:35 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
Re: tranny poly mount worth it
A poly trans mount will bring out any vibrations you have in your driveline, but a well running car shouldnt have any vibrations. so i see no downside, and i have one installed.
Old Sep 27, 2009 | 09:08 PM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
im with ATX, i felt a difference with a poly mount for sure....but they are a far more secure way to go, especially in a performance environment
i've broken more than a couple rubber ones myself before i went poly and i wont go back
Old Sep 28, 2009 | 05:18 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
me three. Also, the poly version has an internal steel interlock, it can't separate like the stock rubber ones always do. While you're at it, do the poly torque arm bushing. It's a bit of hassle, but I'm glad I did mine.
Old Sep 28, 2009 | 05:42 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
I used the stock mount on my GTA but I strapped with two long hose clamps I got at Home Depot. Just wrapped them around the mount. It works like a normal mount except the two straps keep it from breaking. Same idea as a hold down chain protecting a rubber motor mount. Works great. Cost maybe 3 bucks.
83 Crossfire TA
Jan 3, 2016 01:26 PM
Jetmeck
Sep 4, 2015 12:29 AM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
