t5 poly mount and bushing on t56?
Old Sep 28, 2009 | 02:16 PM
firechicken_3's Avatar
Car: 1984 Firebird
Engine: 350 Terminator EFI
Axle/Gears: 4.10
from the looks of things i can reuse my poly trans mount and torque arm bushing with the t56 im putting in right?
Old Sep 28, 2009 | 11:04 PM
vexter's Avatar
Car: '88 Iroc
Axle/Gears: 3.45
Re: t5 poly mount and bushing on t56?
I did... I believe they're the same.
Old Sep 29, 2009 | 03:23 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
The TA bushing is the same and so is the Trans mount, but the Torque arm mount is different. You may know this though. The bushing in the torque arm mount will fit in either the auto or manual TA mounts, though, so you can reuse that part.
Old Sep 29, 2009 | 01:10 PM
Car: 1984 Firebird
Axle/Gears: 4.10
ok, i looked at things last night and that does appear to be the case so i just need to
remove the rubber again like i did when i put the poly torque arm mount on the t5... the t5 bracket looks very similar to the t56 piece i wonder if they are the same? maybe save myself the trouble of the rubber removal again?
also torque spec for pressure plate bolts? i found a site that says 52lbs?
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
tonys91rs
Sep 2, 2015 07:07 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
