gear noise
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
gear noise
alright so i got my 9 inch in tonight and took it down the road. my rear end is making a lot of noise typical gear wine from when the pattern isnt right. problem is i know the pattern is correct. now my question is i used the old 4.11 detroit locker setup out of my dads drag car. could a new pattern on a set of gears cause it to wine like this. if so should i be considering new gears to solve it or will it be ok.
Engine: 383
Re: gear noise
well were not exactly positive if its a street gear or pro gear. dad set it up and the pattern was good when we put it in. yes we used new bearings.
Re: gear noise
Just a guess but with that ratio, I would say they were cut as racing gears. So the way the gear teeth were made you are going to hear noise & wine. So you are have to learn to live with it or buy different gear set.
Engine: 383
Re: gear noise
i dont mind the noise my old rear made it. i just dont want to tear anything up.
and all ask my dad tonight how he set up the preload
Engine: 383
Re: gear noise
alright so pinion bearing preload was set to 13-15 inch lbs. and the carrier bearings we set backlash and made a good pattern then tightened down with a punch cause we didnt have a wrench for it.
Engine: 383
Re: gear noise
right in the middle on both sides of the gear. like i said it should be a good pattern
if its just noise i dont mind it so much i just dont want to tear anything up
UltRoadWarrior9
Sep 2, 2015 08:24 PM
